  #1
Old February 7th, 2008, 05:32 PM
scottsbws scottsbws is offline
Default mercury 175xr2 won't turn over
I have a 97 sea rayder jet boat w/ merc175. To start engine you turn key to on and press rocker switch to turn over. There is also a safety switch attached to a lanyard. Does the engine have a safety switch that will not allow it to turn over if it isn't in the water or there is no water running thru from a hose. I'm not trying to start it...I'm just trying to give the starter a quick bump to see if it's operational. I don't want to run water thru it since it is winterized.
  #2
Old February 7th, 2008, 06:16 PM
Chris1956 Chris1956 is offline
Wink Re: mercury 175xr2 won't turn over
Scott, The starter will not spin if the motor is not in neutral.
  #3
Old February 7th, 2008, 06:29 PM
Default Re: mercury 175xr2 won't turn over
It is in neutral. I also checked the back of the on/of rocker switch. There is power coming in and going out when pressed but no power makes it to the solenoid. I jumped the solenoid and it worked. I inherited this boat and I know it runs..but I think I'm missing a step somewhere.
  #4
Old February 7th, 2008, 07:55 PM
Silvertip Silvertip is offline
Is the rocker switch something that was added? Normally you turn the key to START. Push in on the key while starting to richen the fuel mixture on a cold engine. I have no idea what the rocker switch has to do with anything.
  #5
Old February 8th, 2008, 10:07 AM
j_martin j_martin is offline
It sounds like simple problems have been complicated by jury rigged wiring to compensate. I'd rewire it to stock, replacing any failed components, like the ignition switch, and enjoy a reliable system.
As far as the present stuff goes, I've seen boats wired from factory with those durned clip on (insulation displacement) taps. In a marine environment, water, or worse yet salt water gets into the now unprotected metal, and with an electrical potential on it, it turns into a sacrificial anode and just disolves into an open circuit. I suspect the switch you talk about is wired in parallel with the start contacts of the ignition switch with just such wiring taps.
When you're rewiring, replace any such taps with soldered, and well insulated connections. Liquid electrical tape, and adhesive lined shrink tube go a long ways toward this end.
hope it helps
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mercury 175xr2 sport jet kempkerm Mercury & Mariner Outboards 4 September 12th, 2005 10:40 AM
Merc. Sport Jet 175xr2 Help jojoe72 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 May 25th, 2004 06:06 AM
Help with Mercury 175xr2 repair jojoe72 Mercury & Mariner Outboards 0 March 27th, 2004 11:02 AM
Merc 175XR2 SportJet bierman123 Mercury & Mariner Outboards 4 August 28th, 2003 03:50 PM
99 225 mercury, can turn flywheel one turn then it stops HELP! jsmith55 Mercury & Mariner Outboards 5 April 29th, 2003 08:24 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
