  #1
Old February 6th, 2008, 10:21 PM
bottomline bottomline is offline
Send a message via Yahoo to bottomline
Default '89 Evinrude 150 V6 Ignition Switch Wiring Order???
I need to know the wiring order for the ignition switch. I have the black and yellow on the main M and then I have black on the other M, yellow/red on the S terminal red/purple on the B, purple on the A, and purple/white on the C. When I turn the key to the on position the starter engages like it does when you turn the key all the way to the momentary on position nor ally, which ones have I pput on backwards....thank you very much for any help you can give me.
  #2
Old February 6th, 2008, 10:24 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Default Re: '89 Evinrude 150 V6 Ignition Switch Wiring Order???
__________________
Chris
  #3
Old February 6th, 2008, 10:32 PM
ezeke ezeke is offline
Use this link and you won't be violating anyone's copyright:
"http://continuouswave.com/whaler/reference/ignitionSwitch.html"
  #4
Old February 6th, 2008, 10:36 PM
HighTrim's Avatar
tks Ezeke
__________________
Chris
  #5
Old February 6th, 2008, 10:54 PM
Exclamation Re: '89 Evinrude 150 V6 Ignition Switch Wiring Order???
thank you very much for replying to my question, but therein lies my true dilemma. I have a manual and that is the way it lists it too, but to the letter I have it wired exaclty the way you're posts and the book says to yet I still have the starter engaging in the "on" position as opposed to the "start" position. its about to wear me out!!!
  #6
Old February 6th, 2008, 11:03 PM
When the switch is turned to start, the power goes to the first small post on the starter solenoid, so a short anywhere but the ignition switch is pretty near out of the question.
I would disconnect the wire from the "S" start position on the ignition switch, put a voltmeter between that and the black ground wire at "M", and take a reading with the ignition switch turned to Run. If you show voltage, replace the switch.
BTW, disconnect the battery whenever you do anything around that control; its a real money saving practice.
  #7
Old February 6th, 2008, 11:12 PM
perfect, thank you very much for your help, Ill let you know what it turns out to be. I guess I naively took for granted that since the switch was brand new from the dealer that it MUST be "perfect", for the price, it shouldve included installation...lol, thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Ignition switch wiring, 97 Evinrude bilehuwh Johnson & Evinrude Outboards 5 September 3rd, 2005 07:07 PM
40hp evinrude bigtwin wiring to ignition switch mike40hp Johnson & Evinrude Outboards 4 January 16th, 2004 09:26 AM
1981 Evinrude 35 hp Ignition Starter Switch Wiring Diagram ryan_scs_inc_outdoorsman Johnson & Evinrude Outboards 2 September 20th, 2003 10:21 PM
Ignition Switch wiring pattern for 200 Evinrude joeday Johnson & Evinrude Outboards 0 August 19th, 2002 05:54 PM
ignition switch wiring stinger1 Mercury & Mariner Outboards 6 August 9th, 2001 06:27 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
