  #1
Old February 6th, 2008, 04:33 PM
tytoolbelt tytoolbelt is offline
Default 140 TRL Evinrude Compression
I'm new with motors in general. Never done a compression check. Is there a Compression 101 thread on here somewhere. I am looking at a rebuilt 140hp Evinrude with (what he says) has 10 hours on it. Everything looks rebuilt and new. What should the compression be? I've read and it sounds like 120 to 130 psi. Is this correct? How exactly do I go about doing one of these checks? Both plugs out? One plug out? I do know from reading that it should be a warm engine when doing it.
Thanks in advance for all responses.
Ty
  #2
Old February 6th, 2008, 05:49 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Default Re: 140 TRL Evinrude Compression
As long as it's even, no less than 15 lbs difference between high & low. 120 to 130 may be a bit high for that motor. You can try it with all the plugs out but on loopers you may have to take out 1 at a time. Just try it and see. make sure you have a good charge on the battery. No matter how you do it, do it the same every time.
  #3
Old February 6th, 2008, 06:51 PM
flabum flabum is offline
Depends on the year of the motor. The older crossflow 140's will get upward 120 - 130 on a compression test, the loopers are generally lower. As long as the highest and lowest readings are within 15% (as staed earlier) you should be good. If the motor is a loop 140 ('87 or newer), the the heads may have been shaved some and you will need to run higher octane fuel to keep it happy.
  #4
Old February 6th, 2008, 07:04 PM
ezeke ezeke is offline
I think that the last TRL 140HP is 1983 which makes them (TRL) all crossflows. If the rings and cylinders are in good shape and you test with all the plugs out, you should be in your range if you are at sea level or near it.
  #5
Old February 6th, 2008, 07:36 PM
Thanks guys. I will go get a tester and test it out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
(Compression) 85 hp evinrude howsab0007 Johnson & Evinrude Outboards 3 August 1st, 2006 08:11 AM
compression evinrude louie bb Johnson & Evinrude Outboards 3 November 13th, 2005 06:57 PM
91 150 evinrude compression cowboyup Johnson & Evinrude Outboards 13 February 27th, 2005 01:26 PM
'85 Evinrude Compression #4 Chester797 Johnson & Evinrude Outboards 3 December 4th, 2003 03:34 AM
150 hp evinrude compression? fuzzyrickt Johnson & Evinrude Outboards 3 August 17th, 2003 07:55 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
