Re: Tach for 25hp Mariner
If you have electric start, then the motor probably has a charging system and you can hook up a tach gauge to it. The shop manual for your motor will show this too. If for some reason you are not able to connect a tach gauge to your charging system, I have heard good things on the use of Tiny-Tach, which can be fitted to a motor without a charging system.
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
