Re: Engine Hours
As far as oil analysis, we have it done thought some of our dealers. Our big trucks are done by MHC Leasing from whom they are leased.
Do a search on the web and I am sure you will find someone in your area. It is very common for big diesels.
As far as hour meters go, some will not run at idle or they will slow down. Others will go full bore.
I agree with overestimating the hours put on boats. I has just started fooling with power boats but I find it is true on ATV's. I also find the same thing on the portable forklifts we use.
If you all are wondering why I deal with all this stuff, I am a farmer. I raise turf and rice.
Back to oil analysis, If I were buying a boat with an inboard or a four stroke outboard, I think I would have it done. It is not expensive and can tell you whole lot. Combine analysing the oil and a compression test would eliminate a lot if future problems. If they both checked out good, you most likely have a pretty good motor. Crank case oil analysis would be the first thing I would do if the boat had a diesel(s). They can spend a whole lot of money in a big hurry.
I never though about it but you could probably have the oil in the lower unit analysed for an excessive amount of metal and/or moisture. It sure would be worth talking to someone about because I bet they could detect corrosion. I will see what I can find out next week. I have several sources of information.
Sorry my post is long and rambling. It has been a very long day.
Good Luck,
Grits
