Re: What is idle and max timing for '93 135V6
On the V6's, idle timing is after TDC. Idle pickup sets the timing where the carbs start to open. Actual idle timing is done in the water in gear. It will vary from engine to engine.
If you go through the link n sync procedure religeously, it'll be close if it's otherwise reasonably healthy. (compression, leak down, spark, etc.)
hope it helps
John
