ForkFisher
- Jul 29, 2007
- 16
Hi all
I have a 1978 Evinrude 115hp that the Tilt Trim valve body is screwed up. I have another that I want to put in, but as always I do not have all the right equipment, like an engine lift.
This engine has apparently the old style transom brackets that dont allow you, once the T&T is unbolted, to simply pull the unit out. My understanding is that I have to remove the mounting bolts from the port bracket so the bracket can be moved. I have done this. The engine right now is resting on the two starboard mounting bolts and a set of saw horses.
I cannot get the port bracket to swing up out of the way and I cannot get the bracket to move to the left any to allow me to pull the T&T unit out from between the transom brackets.
Anyone have any help they can give me, like what do I need to do to get this done and get the replacement installed?
All comments will be appreciated.
Thanks.
Thanks.
