Re: 1986 Mariner 150 HP Compression test?
yep, the cylinder. What color and deposits are on the spark plug could give you a clue to what's going on without taking off the head.
If a ring is stuck in the piston, it could degrade the compression. If it comes loose with a little penetrating action it could help. De-carbing fluids, like Sea-Foam, Power-tune, etc are basically penetrating oils and solvents. The readings all over the board suggest stuck rings.
If there's aluminum on the plug, yer in deep doo-doo. Likewise if you peek in the spark plug hole and it looks like someone went to town with a chipping hammer on the piston. If the plug looks like it's steam cleaned, ya got a bad head gasket, and so forth.
Post a good close up sharply focussed picture of the plug.
hope it helps
John
