Hi everyone,
I recently bought a Bluewave CC 190 classic with a 90TLR yamaha 2-cycle. I noticed that by putting the key in the on (not start) position the overheat indicator was blinking the bottom right corner. It has the yamaha digital multi function tach. I proceeded to take it out on the water since I noticed the hour meter was still at zero and started the normal break in of the motor. The light flashed the whole time (no audible alarm) but the motor never got hot and the pee stream was nice and strong. The water temp was around 62 degrees and after about 30-40 minutes I placed the boat in neutral and checked the pee stream, it was barely warm. Continued on for another 30-40 minutes, still flashing.
After I got home and a few hours of cool down I hopped back in the boat and just put the key in on. After the initial led test the overheat indicator was still flashing with a cold engine. Any suggestions? I hate to drive 60 miles to the dealer but would rather do that than burn up a new motor. Also has anyone seen an after market manual for these. The ones I seen only go up to 2005 on the yamaha 90s.
Thanks!
Rob
Thanks!
Rob
