  #1
Old January 31st, 2008, 01:44 PM
newbie38 newbie38 is offline
Default Parts for Zodiac F470?
Does anyone know where I can buy parts for my zodiac F470? Specifically, I am looking for valves and plugs for the self-bailers (or some kind of ball-stop that will go in the two holes to let water out, but not in; for some reason the self-bailer flaps are not doing their job). Any help would be greatly appreciated. Thanks!
  #2
Old February 4th, 2008, 05:54 AM
tacman55 tacman55 is offline
Default Re: Parts for Zodiac F470?
There are many places that you can get parts for the FC470, unfortunately very seldom as good used or at a cheap price. Most Zodiac Dealers will be able to order them but some dealers are more knowledgeable of the military boats than others. I have restored or maintained several 470s for SAR work and have had the best luck with Donovan's Marine near New Orleans...(Donovan Marine, Inc. Donovan Marine, Inc 6316 Humphrey's Street Harahan 70123. Phone: 800-347-4464. Fax: 800-774-6690.) Good Luck... They are great boats if you learn how to use and maintain them right.....
  #3
Old February 6th, 2008, 06:10 PM
Thanks Tacman. I've only had this boat a short while, but so far it has been a blast. It's a hit with my young son too.
  #4
Old February 8th, 2008, 04:22 PM
You are welcome... Let me know if there is any other way I can help....Also in response to your bailer problem... they are desigend to allow water to flow out under its on force but not into the boat... Are the hypalon sleeves still intact and how long are they? If both scupper sleeves are intact and at least 5 to 6 inches long.. they should work... what I would do first before plugging them.. if they seem to be in good condition but do not close when water is not flowing out.... I would take two boards or something hard with a smooth edge and sandwich the scupper between them using weight or clamps to hold the scupper/bailer flat.. I would try this and leave it for a while and see if that gives them some memory to stay flat and closed.. If that does not work.. insted of plugging them... you could place grommets in the ends of them and run a line through the grommets with a knot in the end.. and when not under way or when their is not water in the boat.. you can have them pulled up and the lines hooked off to clips or eye bolts on the inside of the transom.. but when you need them to drain water.. lower them and run..... Hope this helps.......
  #5
Old February 20th, 2008, 10:12 AM
Thanks Tacman. My situation is kind of an odd one. As you know, there are two bailers in the transom; one above the hard deck and one below. The one above works fine. The one below happens to be positioned directly beneath the mounting bracket for the 40 hp Merc I have on the boat. The end result is that the scupper is pinched up enough so that it never fully closes. It seems to be pinched up enough that water cannot quickly run out when I am on plane, but when I am at rest it comes in pretty steadily. Honestly, short of trying to find another mounting bracket I am beginning to think plugging the bailer is my only option.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Zodiac F470 Bailer question newbie38 Zodiac Boats 8 July 23rd, 2008 04:20 PM
zodiac or not>? bazrfc Zodiac Boats 3 November 14th, 2007 12:51 PM
zodiac f470 navigation lights question newbie38 Zodiac Boats 5 August 23rd, 2007 06:06 PM
zodiac f470 navigation lights question newbie38 Electrics, Electronics and Trolling Motors 0 August 15th, 2007 12:55 AM
Zodiac?????????????? Moosehunter Zodiac Boats 4 March 14th, 2006 06:39 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
