tomynoks
- Jan 1, 2007
- 252
Hopefully this is a silly question.... Does this motor lock into position for raising, lowering and trailering? I know it locks in the "up" position, but I cannot figure out how to lock it from turning port and starboard. The steering cable holds it somewhat, but not enough. I found part #383618 which is described as "shaft and lever assembly" but it doesn't seem to do anything. There is a spring attached to it called "spring, reverse lock". Finally got this old beast running, now I'm trying to fine tune and learn all I can about it.
Thanks,
Tom Smith
Thanks,
Tom Smith
