  #1
Old January 29th, 2008, 08:54 PM
nogimmies nogimmies is offline
Default 1992 yamaha 4 stroke 9.9 idle problem
Engine starts then runs ok for 30sec to 1 min then starts to sputter and dies.
Wait 2-3 minutes and restart with same thing happening
Cleaned carb checked jets and passages
checked filter ,fuel pump
when I loosen the Electo thermal valve runs for a little while longer and dies again
Thinking it may be the valve but reistance checks ok.
Puzzled on this one.
Click it into gear and rev for a while and runs ,but dies at idle.
  #2
Old January 29th, 2008, 11:31 PM
ryoung ryoung is offline
Default Re: 1992 yamaha 4 stroke 9.9 idle problem
One other check for the thermal valve is to remove it from the motor and connect the leads to a 12 volt battery. The needle should extend as it warms up, this closes the cold start enrichment jet.
  #3
Old January 30th, 2008, 02:16 PM
Needle did not move after on 12v for 3 minutes.
Checked again with meter and circuit is bad
Orderd a new electrothermal valve unit and some other parts.
Hopefully this will solve the problem.
Thanks for your input
nogimmies
  #4
Old January 30th, 2008, 05:39 PM
Got it running without the ordered parts.
After all that fuss I found that the Air idle screw needed to be backed out another 1.5 turns to about 5.5 turns total vs 2-4 as manual calls for.
As soon as the thermovalve does its thing the engine would quit.
Not now
Engine runs like a Jap/swiss watch.
Now for my next endeavor
Changing the 9.9 to a 15 with some new jets.
I'll post my results.
nogimmies
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1992 yamaha 4 stroke 9.9 to 15 hp nogimmies Yamaha & Suzuki Outboards 1 June 21st, 2009 03:00 PM
2004 25 hp 2 stroke yamaha idle problem speckman25 Yamaha & Suzuki Outboards 0 May 14th, 2006 03:52 AM
1992 Yamaha 4 Stroke-Idle & StartProblem Condor1 Yamaha & Suzuki Outboards 3 July 28th, 2004 09:46 PM
Yamaha 115 four stroke idle problem ReelSlick Yamaha & Suzuki Outboards 0 July 10th, 2003 11:49 AM
1992 Yamaha C40 rough idle Boat_Boy! Yamaha & Suzuki Outboards 10 August 3rd, 2001 03:06 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
