  #1
Old January 29th, 2008, 02:02 PM
Billwilky Billwilky is offline
Default What Pitch for a 90hp on Pontoon?
Wondering what pitch for the prop I should get. I will be getting an aluminum prop. I'm getting a new 2006 etec evinrude for my Pontoon boat. Empty it weighs 2289lbs. I will be tubing sometimes but mostly just cruising around.
  #2
Old January 29th, 2008, 02:14 PM
JB's Avatar
JB JB is offline
Default Re: What Pitch for a 90hp on Pontoon?
Prop discussions go in the Prop Forum, Bill.
I will move this there for you.
__________________
RED SKY at night. . .
JB
  #3
Old January 29th, 2008, 03:59 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
I'd be looking at a 13" pitch for water sports or a 15" for general cruising, but best to see if the dealer will let you try one and find your Wide Open Throttle RPM's and go from there. Hard to nail it down without specific info...
__________________
Rick
"Boating is Life...All the rest is just Details"
  #4
Old January 29th, 2008, 04:27 PM
steelespike steelespike is offline
2007 Etec 90 op. rng. 4,500 to 5,500 on a Crest 20 ft 2,300 lbs dry.Al.13 3/4 X 13 25 mph at 5,100 rpm,
Premier 24 1980 lbs dry Al.14 X 11 23 mph at 5,600.Its interesting the 20 weighs more than the 24.Also interesting the 11 inch pitch on the lighter but longer boat.I wonder if a 13 on the Premier 24 would have performed closer to the Crest 20s numbers.
  #5
Old January 29th, 2008, 11:26 PM
sc_shane's Avatar
sc_shane sc_shane is offline
Just curious - where are you guys finding these benchmarks? Would be great information for tons of folks, I'm sure. Is it available on the web?
__________________
--=* If you can carry the cooler yourself, go get more beer!!! *=--
1991 Crest 25' Pontoon
1989 Yamaha 90HP
2000 Chevy Tahoe Z71 4x4 V8
  #6
Old January 29th, 2008, 11:48 PM
rogerwa's Avatar
rogerwa rogerwa is offline
I am running a 13P with my Nissan 90. On my Vibo 25 footer with 4 adults and 6 kids, I get 4800-5000 RPM and a speed of about 20mph.
I am thinking about going to an 11p to get my RPMs up higher, but unless it gets more efficient (less slip) I will lose top end.
__________________
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
-Thomas Jefferson
  #7
Old January 30th, 2008, 01:04 PM
walleyehed's Avatar
walleyehed walleyehed is offline
Keep letting that engine run 4800-500 at WOT and you won't have to worry about top-end anymore....your worries will be which new pistons to install.
  #8
Old January 30th, 2008, 03:50 PM
Quote:
I just go to the BRP site Thay have many many performance tests all kinds of boat/motor combos 40 hp up.You can usaually find something close to the boat/motor in question.
  #9
Old January 30th, 2008, 03:59 PM
Where is your rpm & speed with a light load?
  #10
Old January 30th, 2008, 05:57 PM
I do not have it on the boat yet. The man installing it said that on bass boats they run about 5600 rpm. He said with my weight (2289) it would be less. He wanted to put a 15 pitch. It sounded odd to me. Thats why I'm asking for opinions. It is a 24ft Fisher Pontoon 1995. I checked the BRP site but did not see these kind of test on there. What drop down line do I look under?
  #11
Old January 30th, 2008, 07:46 PM
sc_shane's Avatar
BRP site? I'm lost. I went to BRP USA and couldn't find anything. Do you have a link?
__________________
1989 Yamaha 90HP
  #12
Old January 30th, 2008, 09:05 PM
rogerwa's Avatar
Quote:
At 5000 I am just at the bottom of the specified RPM range. This spring I am going to look at moving the motor up a notch as i think it is too deep, do a carb cleaning, and pop an 11 on there to get into a more comfortable range.
As for what it does unloaded, I am not sure. It does fly though easily surpassing the 5K mark. If only I could convince all those people to stay at the dock..
__________________
-Thomas Jefferson
  #13
Old January 30th, 2008, 09:17 PM
Quote:
I'm thinking 15 is too much but if they let you try props till it's right you could start there.
Keep in mind you want your rpm so it is within upper range with your typical load.
Vertical height is tricky on a toon it may take some fiddling to get it right.I lean toward a setting with occasional minor venting.
For BRP use google; put in ETEC outboard.Click "Evinrude etec promo"click on any motor then put cursor on motors and click on your hp package then click on specific hp.You'll see
basic description with tabs above.click on performance reports.
  #14
Old January 30th, 2008, 11:11 PM
walleyehed's Avatar
I'm with steelspike..a 15 will be too much...13 may be close, but you want to prop for the top of your range with the normal load.
  #15
Old June 12th, 2008, 02:13 PM
papasage papasage is offline
Talking Re: What Pitch for a 90hp on Pontoon?
i have a 40 hp tohatsue on my 20 ft pontoon . got a ss 16 pitch . i could swim faster than it would go . I CAN`T SWIM . it was slow . it has a 4 blade not sure of pitch but thinl it is less than 13 . no # on it . got a ss new for $100.00 plus shipping if anyone needs it .
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
which prop 25" pontoon 1982 90hp Evinrude tbrracer Prop Questions and Topics 4 July 25th, 2009 02:57 PM
98 Honda 90HP 20' Pontoon PROP ISSUES MuskyHunterDave Honda & Tohatsu/Nissan Outboards 6 March 13th, 2006 09:23 AM
pitch of prop for my 90hp Rude? Oscar^Boy Boat Topics and Questions (not engine topics) 7 June 19th, 2003 08:40 PM
pitch of prop for my 90hp Rude? Oscar^Boy Johnson & Evinrude Outboards 7 June 19th, 2003 08:40 PM
pontoon pitch with insane tach.... joakes Boat Topics and Questions (not engine topics) 2 July 20th, 2001 06:43 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
