Re: 1985 force compression
What do you guys think of a 83 85 FORCE outboard with 85 psi on all three cylinders? The majority of the compression readouts that i have seen usually have 120 psi or more. Is having 85 psi on my outboard acceptable or does it mean that im losing power and a rebuild might be in order. I can get her up to approximately 32 mph on a 16 foot bayliner. This is all the speed that i need considering i mainly tube and fish from it. Thanks guys.
My 85 85hp has not been rebuilt, and it registers 130psi on all 3. The 85hp Force is pushing an '85 Bayliner 1600 Capri Cuddy (16 ft). On a very smooth, calm lake, I did a max of about 40mph trimmed fully in with just me and 9 gallons of gas. Can probably do better with a little trim adjustment. Out on the bay with fair weather, I was able to do 38mph, but I also had the Navy top on it, and that may cause some wind resistance, plus I had the kids and some gear.
If your Bayliner is a bow rider, it is a 120lbs or so lighter than my Cuddy Cabin. My guess is your horse power is suffering a bit from lower compression, and/or the boat is carrying a bigger load than I was and/or there is wet foam loading it down and/or your speedo is off and/or we have different pitch props.
BTW, the speeds were determined by the factory speedo (pitot style). But that shouldn't account for an 8 mph difference.
The bottom line is as long as its performance is consistant, then there is nothing to worry about. Although you are probably right that at 85psi, it is showing its age. Doesn't mean its going to blow up tomorrow, but it is worn, I would just use it as is as long as you can.
