Re: 1984 85 HP runaway engine
I suppose the person from whom you bought the boat did not bother to give you rudimentary instructions. --Just as an aside, when I sell an engine, I include about two typewritten pages of instructions AND go over starting procedure with the buyer.--
To start the engine for the first time a simple but important procedure must be followed:
1. pump the primer bulb in the fuel line until it is firm, indicating that the carbs are filled
2. Depending on your control, either push in the center rubber button and advance the throttle lever as far as it will go --or--pull out the control handle about 1/4 inch and advance it as far as it will go. This puts the engine in fast idle position in neutral and will allow it to rev up to about 1500 rpm for warm up. Sounds fast but really isn't. The engine is normally run between 5000 and 5500 rpm at full throttle.
3. Turn the key to start position while pushing it in to choke. Release when the engine starts.
4. Let the engine warm up for a few seconds or so --differs with each engine, you will learn what your's needs-- Pull the control handle back to straight up neutral position. If it has a center button, it will automatically reset; if it was pulled out to advance, you must push it back in. If the engine stalls, it was not warm enough--restart but try without choking it first so you don't flood it.
5. Push the control handle quickly about 1/4 of its travel to put the engine in gear. You will hear it "clunk" this is normal. Do not try to "ease" it; You will hear it "rattling" --this is harmfull to the lower unit dog clutch. Further forward travel on the control accelerates the engine. Forward is forward and backward is reverse.
Depending on the state of your engine, when starting warm, you may be able to just turn the key; you may not need to put it into fast idle and you may not need to choke it. You definitely will not need to pump the primer bulb. That is only necessary if the boat has been sitting for days and the carbs and fuel line went empty.
