January 24th, 2008, 07:54 PM
Adding Yamaha Fuel Managemant to Old Motors?
Can I add the system to my 1991 twin Yam 250's? What would I need? Thanks
January 24th, 2008, 08:34 PM
Re: Adding Yamaha Fuel Managemant to Old Motors?
sure
just buy the twin kit.
it will have two fuel flow senders,the guage and the wiring harness.
January 25th, 2008, 08:50 AM
Thanks, is it the same part # as the kit for new F250s? Do they use the same harnesses?
January 25th, 2008, 09:26 AM
for analog yes, for command link, which your motors ECU wont support, no.
January 25th, 2008, 10:12 AM
6Y5-W0088-64-00 is the part number for a fuel management gauge for an analog 2 stroke motor with dual engines.
January 25th, 2008, 01:26 PM
Thanks, if they made the same ones for so long then maybe I can find a used set.
February 10th, 2008, 08:46 AM
Will the combo speed and fuel management guage work with twins?
March 6th, 2008, 09:55 PM
I hope so. I just bought the combo guage and now need the harness and fuel sensors. Does anyone know what the correct part numbers are?
Thanks
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
