  #1
Old January 24th, 2008, 07:07 PM
Abstraxx Abstraxx is offline
Default 2003 25hp Mercury Cooling Question
I just purchased a Fisher 14' aluminum boat with a 2003 25hp Mercury Model# 25EL
Same as pictured at this link:
"http://www.smalloutboards.com/m2503let.htm[/url]
I have not taken out on the water yet but having been doing some maintenance such as:
New Plugs
New Prop
Changed lower gear oil.
My question is on the cooling. How does it work?
When I throw the muffs on and started her up after I bought it she had a steady stream of water shooting from the telltale.
Soemone told me the water should come out through the prop as well? If so it does not.
The other day I started it with the muffs but the teltale was not a steady stream it was more like spurting out and after a few minutes some smoke(heat) was coming out the telltale.
I start it today and the teltale is a steady stream again. I removed the Prop and can stick my finger in the whole where the exhaust is coming out but theres no water.
How should the cooling work and do you think there may be a problem?
Thanks
  #2
Old January 24th, 2008, 07:47 PM
Laddies Laddies is offline
Default Re: 2003 25hp Mercury Cooling Question
It is always a good idea when you don't have maintance records with a engine to repace the w/pump. It should have a good stream at the telltale when warm and no exhaust or steam, however if the hose did not have enough volume it could act as you describe. When connected to a hose without the engine running if you have water out the telltale you for sure have a bad impeller and when running the water should show a increase of pressure when you increase the RPM, never run a engine on a hose over 2000 RPM
  #3
Old January 24th, 2008, 08:31 PM
Should the water come out the propeller when you have it running on the muffs?
Where else does the water come out of other than the teltale?
The ad for the motor said new water pump and when I look at it the guy said it had a new water pump and he always changed it every year.
By the way what happened Mercurypartsexpress.com Sites been down?
I would like to see if this engine has a thermastat.
  #4
Old January 24th, 2008, 11:08 PM
Yes the engine should have water coming out of the prop about 90% of cooling water goes out the exhaust. BAM Marine site has very good parts manuals for all Mercury products.
  #5
Old January 25th, 2008, 12:31 AM
If it has a thermastat would that not allow water to shoot out the exhaust untill it was hot enough? IF not what would cause the teltale to stream but no water out the exaust (prop)
I ran it for approx 6 minutes, had the telltale streaming but no water out of the prop.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2003 Mercury 25hp long shaft-low rpm at wot 10 FOOT INVADER Mercury & Mariner Outboards 0 April 30th, 2007 02:06 AM
1969 Johnson 25HP Cooling Question mattyb45 Johnson & Evinrude Outboards 6 August 16th, 2006 02:32 PM
2003 25hp nissan 2 cycle question Tommy Kelly Honda & Tohatsu/Nissan Outboards 6 April 7th, 2006 09:52 AM
Release lower shaft 2003 25HP mercury 2stroke jacob10 Mercury & Mariner Outboards 1 March 25th, 2006 02:40 AM
25hp Mercury Cooling - Thermostat Help jakeboomer Mercury & Mariner Outboards 7 November 17th, 2005 11:29 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
