  #1
Old January 21st, 2008, 10:18 PM
fmrodrigue fmrodrigue is offline
Default 1988 evinrude 70 vro lower unit question
my 70 hp evinrude jumps out of reverse when reved up in the water but not on the trailer. I have checked the shifter cable and its ok. I can hold down the shifter mechanism on the motor (in the water) and it does better but when torqued up at full throttle reverse it still jumps out of gear against my force of holding it back manually. Someone told me it could be a linkage malfunction in the housing but I dont really know where to look for this. Any sugestions greatly appreciated.
  #2
Old January 21st, 2008, 10:21 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Default Re: 1988 evinrude 70 vro lower unit question
I would first try disconnecting the linkage at the motor and shifting manually to isolate the 2.
If it still does it it could be your dog and gear. The lobes of the dog and gear are precisely machined with sharp angles. When these edges wear, it forces the lobes apart when rpms increase, jumping out of gear. This is mainly caused by improper shifting. You need to shift with a deliberate movement, snapping the unit into gear as quickly as possible.
It is not "revving" up is it, as in a spun prop hub is it?
__________________
Chris
  #3
Old January 21st, 2008, 10:26 PM
disconected reverse cable and it still did it. forward gear runs great so prop isnt a problem. only does it when there is resistance to the motor from the water. runs in reverse fine in the water idling and up to about 1000 rpm then it jumps out of gear. would a clutch dog cause this problem only in reverse?
  #4
Old January 21st, 2008, 10:33 PM
  #5
Old January 21st, 2008, 10:45 PM
HighTrim's Avatar
I hope its not and someone jumps in with a solution. I dont want to be the one to tell you the price of the shifter and reverse gear.
"http://www.crowleymarine.com/brp_parts/diagrams/27508.cfm"
__________________
Chris
  #6
Old January 21st, 2008, 11:21 PM
thanks for the web page to crowley marine. they have a great view of scmatics and price list
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1988 evinrude 70 vro lower unit question fmrodrigue Johnson & Evinrude Outboards 2 November 27th, 2007 11:40 PM
Oil + Water seeping out above lower case unit – 1988 60 HP Evinrude MiloKnezevic Johnson & Evinrude Outboards 6 August 21st, 2007 08:58 AM
1988 evinrude 88hps lower unit stuck oneverybadwolf Johnson & Evinrude Outboards 4 July 5th, 2007 09:35 PM
77 evinrude 70 hp lower unit question kdsimo Johnson & Evinrude Outboards 2 June 21st, 2006 06:44 AM
Evinrude Lower Unit Question. Baitcaster Johnson & Evinrude Outboards 2 January 31st, 2005 04:07 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
