Steering Friction Screw Issue/Question
mentalone
My last trip taking the boat out, I was tightening the motor steering for travel. As I did, the motor didnt get very tight, and seems that the screw may be stipped. The screw tights to a point, then pushs out slightly and the steering never gets too tight. How can I fix this issue? Has anyone else had this issue before?
I typically tighten and loosen the screw while transport to keep the motor upright so it doesnt fall to either side while driving. I loosen it when in use so I dont have to strain to push the lever.
Thank you,
Dan
Dhadley
Re: Steering Question
Welcome!!
We'll assume you have a tiller steer motor but for anyone to give an accurate answer we'd need to know what motor you're actually working on.
mentalone
Sorry for leaving that out. Its an Evenrude 15 hp 4 stroke.
Thank you,
Dan
mentalone
The Model Number is B15RL4ss.
The part is the steering friction screw. I hope this helps.
Thank you for your help.
