  #1
Old January 21st, 2008, 06:57 PM
oonighttrain oonighttrain is offline
Default RODBOLT or yamaha guys! Yamaha 50hp 4 stroke low compression question!
hi, i saw your past posts and it lookslike you really know your yamahas.. any help from anyone would be greatly appreciated!!!
i have a 1997 yamaha 50 hp 4 stroke that runs ok but, has very low compression on cylinder #1 (like 30 p.s.i)and slightly low compression on cylinder #4. (around 90) 2 and 3 are over 120 psi....
i removed the head to take a peek and do not see any damage whatsoever on the cylinder walls. i took the head to a machine shop so they can do
a vacuum test on each valve. im hopingthey find something wrong so i dont have to get any deeper into the engine.
thanks!!!
  #2
Old January 21st, 2008, 08:08 PM
drewmitch44's Avatar
drewmitch44 drewmitch44 is offline
Default Re: Yamaha 50hp 4 stroke low compression question!
Shame there is not like a "compression adjustment" screw. You could adjust that! LOL Its like, awww man my 4th cylinder compression is low like 20 psi. You could just turn it up! LOL Anyways man i hope everything works out for you and you dont have to rebuild.
  #3
Old January 21st, 2008, 10:42 PM
Quote:
i think your on to something there.... you could make a fortune!!!
by the way.. if someone can tell me where my compression adjustment screw is, id appreciate it..
  #4
Old January 21st, 2008, 11:13 PM
noelm noelm is offline
Default Re: RODBOLT or yamaha guys! Yamaha 50hp 4 stroke low compression question!
I hope Rodbolt has a simple explaination for you, but I don't like the sound of it so far, sounds like some stuck rings maybe, but you never know, you may be lucky with a leaking valve or something, a leakdown test would have painted a clearer picture for diagnosis, but the head is off now so just wait and see what they find.
  #5
Old January 22nd, 2008, 12:00 AM
rodbolt rodbolt is offline
vacum test on each valve?
this I really really gotta see.
tell me all the Yamaha 4 stroke certifications hanging on your techs wall.
beyond that, what dummy would ever take a 4 stroke apart without a leakdown test when the reason for loss of compression wasnt known ?
  #6
Old January 22nd, 2008, 08:44 AM
reeldutch's Avatar
reeldutch reeldutch is offline
the numbers are extremely low for a 4 stroke.
these compression numbers are more 2 stroke ish
4strk are depending on compression ratio from model to model, but generaly from 150 al the way up to 220 psi.
i would defenetly perform a leak down as rodbolt sugested.
good luck
  #7
Old January 22nd, 2008, 09:50 AM
about all that can be done without reassembly is to remove the cam, place the head upside down and fill each combustion chamber with solvent and see if the valve leaks and inspect the old head gasket.
my reccomendation would be to reinstall the head with a new gasket, do a leakdown.
test can be run without the cam installed.
  #8
Old January 22nd, 2008, 10:09 AM
after reading all the posts which by the way, was after i removed the head.. i realize i should have had a leakdown test done..
can they perform the leakdown check if i slap the head back on without hooking everything else up?? thanks!
  #9
Old January 22nd, 2008, 10:19 AM
as the head gasket can only be crushed once you will have to use a new head gasket, IF the headbolts use an angle torque method for final tightness its reccomended to replace the head bolts at final assy.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2001 Yamaha 50hp 4 stroke compression??? yachtnetwork Yamaha & Suzuki Outboards 3 April 21st, 2009 02:52 AM
Need to identify Yamaha 50HP 2-stroke Jonny Yamaha & Suzuki Outboards 3 April 4th, 2007 05:06 PM
Trolling with a 50HP Yamaha 4 stroke jrhofman Non-Repair Outboard Discussions 2 February 7th, 2006 03:42 PM
Compression on 650cc Yamaha 50hp? gr8rg8r Yamaha & Suzuki Outboards 0 June 13th, 2004 05:57 PM
'82 50HP Johnson Compression Question wavebuster58 Johnson & Evinrude Outboards 5 June 8th, 2004 09:39 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
