  #1
Old January 21st, 2008, 10:09 AM
rick_l rick_l is offline
Default Yamaha 4 stroke 25 hp
I am having trouble with obtaining information on a Yamaha 25 hp 4 stroke. It is a 2000 year motor and the Model number is F25ELRY The quetions are:
1. What is the size of the rod journels? I am having the crank rebuilt and need to know the spec size?
2. Why does Yamaha have three different sizes of rod bearings and crank bearings?
I posted these questions earlier but have not received any answers. I counting on you guys.... thanks
  #2
Old January 21st, 2008, 03:00 PM
BruceAML BruceAML is offline
Send a message via AIM to BruceAML
Default Re: Yamaha 4 stroke 25 hp
Why don't you contact Yamaha customer service at (866) 894-1626. They are always helpful. In addition to the model number they will want the serial number. They open at 8:30 AM EST. In addition to the three sizes of bearings there are two sizes of pistons. One is standard and the other is .50 mm over size
  #3
Old January 22nd, 2008, 08:52 AM
I have contacted Yamaha Customer service and they can not answer the questions. I have also contacted three Marina's who have Yamaha Master Tech's and they can't answer the questions. There only response is that Yamaha does not recommend rebuiding the crank. A new crank for this motor is around $#550. to $600. I can have the crank rebuilt for $150.00 and they say they can put it into specs if I get the rod bearing journels specs.
  #4
Old January 22nd, 2008, 10:02 AM
rodbolt rodbolt is offline
yamaha doesnt give us much as a spec as they dont offer oversize bearings like the automotive world.
I can give you the specs from a march 97 manual,
crankshaft outside diameter 42.884-43.000mm (1.692"-1.693")
main journal clearence is .012-.o44mm (.0005"-.0017")
crankcase marks-bearing color. A:Blue,B:BlackC:Brown.
crankshaft big end side clearence.05-.022(.0008-.002")
runout limit is .03mm(.0012")
but as Yamaha does not reccomend nor offers rebuilt cranks best your machine shop can do is measure a non damaged journal and try that.
its either that or measure all the bearing shell thickness and do the math.
  #5
Old January 22nd, 2008, 11:34 AM
Thanks rodbolt, I think that is our best way to go. I am ordering new rods and bearings. They say they can measure the opening and then add the recommended oil clearence to it.
  #6
Old January 23rd, 2008, 08:06 AM
The reason for 3 different sizes of bearings is so that crankshafts are not turned into scrap at the manufacturing plant. Any slight variations are made up by the bearing size. The crank is color coded to the size bearing that is required. Yes, the crankshaft is rather expensive for a 2 cylinder engine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2007 150 yamaha 2 stroke more bulletproof than the 4 stroke klotzy Yamaha & Suzuki Outboards 4 September 10th, 2007 01:16 AM
Yamaha F225 (4 Stroke) vs. Yamaha Z250 (2 stroke) HPDI jhough76 Yamaha & Suzuki Outboards 4 March 14th, 2003 10:11 AM
Merc 115 4-stroke same engine as Yamaha 115 4 stroke? maillon Mercury & Mariner Outboards 3 March 13th, 2003 07:21 AM
Yamaha 40 4 stroke vs. Johnson 40 4 stroke. (By Colson) JB Johnson & Evinrude Outboards 5 December 3rd, 2002 06:30 PM
Nissan 25 2 stroke vs Yamaha 15 4 stroke boatyardbilly Yamaha & Suzuki Outboards 4 August 21st, 2001 05:29 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
