fishkiller
- Oct 30, 2004
- 72
I was thinking of switching to premixing my gas and was wondering if I put stabil and oil in the tank how long will it take to get to all of my carbs(85 140hp v4 rude)? do I need to run engine on lake or will all carbs get mix in it at idle? want to make sure oil/stabil mix is in carbs before winter.
lower unit question is that I have some synthetic pennzoil SAE 75W-90, API GL-5 oil...I am going to replace impeller and housing in the spring should I replace lower unit lube now? is this the right lube? I cracked the drain plug to make sure no water in lower unit and only lube came out.
