Re: Yamaha T60 bogs down @2100rpm
I found this on the Yamaha site.Maby it is a oil thing.
RPM reduction is a mode within the engine warning system. RPM reduction is when the engine forces a reduction of rpm during operation. This can be caused by a couple of reasons: an overheating of the engine or the oil system has a loss of oil pressure (four-stroke models) or low oil level (two-stroke models).
RPM reduction is used as a safety measure to try and protect the engine but also to continue to provide mobility in case it is needed. Your RPM will be gradually reduced down to approximately 2000 rpms. The engine should run fine below 2000 rpms but will run very rough if you try to accelerate beyond 2000 rpms.
Smaller horsepower engines, like an F2.5 or F4, may not come with a warning system, or have limited warning system protection. Ask your Yamaha dealership or Yamaha Outboard Customer Relations, at (866) 894-1626, for more details as needed.
