1996 Mariner 115 carb part numbers...help
I've pulled my carbs and was trying to reference the part numbers to tell if they were WME 33/51/etc. The part number cast into each carb body is 3301-824902C. I can't find that part number anywhere on the mercury parts express website. The main jets I pulled out were not matched to any of the carb part listings. The closest was WME-51. There is a 51-1,2,3,4 stamped on the sides of each (respectively) so I'm figuring they are WME-51. Problem is that one main jet was destroyed during removal so I need to replace it. Upon inspection, the main jets are (from 1 to 4) .062, .06* (the destroyed one), .060, and .064. The WME-51 calls for .062 on 1,2,3 and .064 on 4. Should I replace what was in there or go with what is on the Mercury parts express site? The part numbers for the WME-51 are not the same as stated before (3301-824902C) so I'm wondering if the part numbers have changed or the last owner put some random jets in on some old carbs and stamped the 51 on the side. Any help or insights would be appreciated. Serial number is 0G348734...sorry it was late.
Reason: added SN
