  #1
Old January 18th, 2008, 01:11 AM
Sod Farmer's Avatar
Sod Farmer Sod Farmer is offline
Default Prop for pontoon boat
I've learned alot from this board already, but I need a little help. Most of the threads I've read focus on the pitch of the prop to get the desired rpm's for any boat/motor combination. With that being said, I also understand that props with less pitch and more surface area are better at moving heavier loads. Some of the smaller outboards such as the Mercury "Bigfoot" or Yamaha "High Thrust" engines (60 hp max with either manufacturer) have these larger props with less pitch specifically designed for pontoon applications. Mercury, for example puts a 14x11 prop with little or no rake on their 60 hp "Bigfoot" I am unaware of any props for a larger engine that are similar in design to the ones found on the Mercury "Big Foot" or Yamaha "High Thrust" engines. I am buying a new pontoon that I will equip with either a new Yamaha or Mercury 90hp 4s engine. I plan to see what type of performance I get with whatever prop the dealer puts on it and go from there. When I look at all of the different props available for these engines, I know that I will need to get one with the correct pitch to give me the correct rpm's. However, there are varying degrees of rake and cupping that also affect performance. Given the fact that this is a pontoon that won't be traveling at speeds usually produced by a 90 hp engine, what design features should I be looking for in a prop? WOT should produce a top speed somewhere in the mid 20's. With my application, is it as simple as just getting a prop that gives me the appropriate rpm's at WOT? Are there any companies out there that make props similar to the Mercury "Bigfoot" props that would be useable on a 90 hp outboard?
  #2
Old January 19th, 2008, 11:57 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: Prop for pontoon boat
Mercury makes a double cupped prop wide blade (48-77340CP1 Black Max Aluminum) that works well with pontoons. I run the 14" X 13" on my 20' 2 log toon with a 07' Merc 90 4-stroke. It will run 28 wide open with just me onboard and 26-27 with one or 2 more people onboard. It cruises nicely at 18 MPH at 3900-4000 Rpms. WOT with this prop is 5900...
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
Old January 19th, 2008, 01:08 PM
Sod Farmer's Avatar
That is exactly the kind of info I am looking for! Thanks again!
  #4
Old January 19th, 2008, 01:11 PM
DJ DJ is offline
We have what "rick" has on our two toons. The results are very similar. The engines are a Merc. 75 2-stroke and a Merc. 75 4-stroke.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Need Prop to match 25 ft Voyager Pontoon boat TLR Mercury & Mariner Outboards 2 June 1st, 2009 12:37 PM
Pontoon Boat - Water Glide 3rd Pontoon martybhawk Pontoons 7 July 13th, 2008 11:09 AM
Pontoon boat Prop mrmaxum Prop Questions and Topics 1 November 4th, 2007 10:21 AM
Pontoon boat prop/outboard position help Speedwagon Prop Questions and Topics 16 July 26th, 2006 11:57 AM
Prop for pontoon rickdb1boat Prop Questions and Topics 3 March 11th, 2006 03:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
