  #1
Old January 17th, 2008, 07:45 PM
bernieb bernieb is offline
Default Mercury four stroke 03 efi stalling.
Friends engine. Engine runs fine ,gets to upper rpm ,but when throttling down and going into neutral the engine stalls, also he has about 500 hours on this engine and outside of changing oil and a waterpump nothing else has been done. What else should be done? He takes me fishing is why I'm asking. bernie
  #2
Old January 17th, 2008, 07:52 PM
Don S's Avatar
Don S Don S is offline
Default Re: Mercury four stroke 03 efi stalling.
Is this a 5hp or a 300 hp EFI?
__________________
Don S.
Why is there never enough time to do it right the first time,
But always enough time to do it again?
Please, NO PM's (Private Messages) regarding boat/engine problems.
That is what these forums are for.
Only forum/moderator issues will be answered in PM's.
  #3
Old January 17th, 2008, 08:22 PM
rodbolt rodbolt is offline
I bet its black
  #4
Old January 17th, 2008, 10:26 PM
JustJason's Avatar
JustJason JustJason is offline
it's one of the new high tech multipiston engines... probably over our heads on this one...
__________________
just because you found it that way... doesn't mean it's supposed to be that way.
Part of diagnostics is spending time figuring out not only what the problem is, but also sorting through what it isn't.
The older the engine is, the chances of it having more than 1 problem goes up exponentially
Boating has always been a rich mans hobby. Buying a new boat gets cheaper every year, but the maintenance, the repairs, and the overall cost of ownership of a boat has never gotten any cheaper.
  #5
Old January 18th, 2008, 03:47 PM
rob711 rob711 is offline
500 hours!! ever think of looking at the plugs?
  #6
Old January 19th, 2008, 08:30 PM
Sorry guys for the delay,it's a 115hp
  #7
Old January 20th, 2008, 10:38 AM
Don S's Avatar
Start with new spark plugs, and checking the fuel filters and hopefully he has a waterseperating fuel filter that should be checked for water and replaced.
It could also be a sensor failure or minor adjustment to cause the stalling. Getting a diagnostic test done by a dealer and a diagnostic computer, would be a good idea, before the problem gets worse
This is from the Merc 115 OEM service manual about regular maintenance.
Inspection And Maintenance Schedule
To keep your outboard in the best operating condition, it is important that your outboard receive
the periodic inspections and maintenance listed in the Inspection and Maintenance
Schedule. We urge you to keep it maintained properly to ensure the safety of you and your
passengers and retain its dependability.
Before Each Use
1. Check engine oil level.
2. Check that lanyard stop switch stops the engine.
3. Visually inspect the fuel system for deterioration or leaks.
4. Check outboard for tightness on transom.
5. Check steering system for binding or loose components.
6. Visually check steering link rod fasteners for proper tightness.
7. Check propeller blades for damage.
After Each Use
1. Flush out the outboard cooling system if operating in salt or polluted water.
2. If operating in salt water, wash off all salt deposits and flush out the exhaust outlet of the
propeller and gearcase with fresh water.
Every 100 Hours of Use or Once yearly, Whichever occurs first
1. Lubricate all lubrication points. Lubricate more frequently when used in salt water.
2. Change engine oil and replace the oil filter. The oil should be changed more often when
the engine is operated under adverse conditions such as extended trolling.
3. Inspect thermostat visually for corrosion, broken spring, and to determine that the valve
is completely closed at room temperature. If questionable, inspect thermostat as outlined
in Section 4B, Thermostat.
4. Inspect and clean spark plugs.
5. Check engine fuel filter for contaminants.
6. Check engine timing setup.
7. Check corrosion control anodes. Check more frequently when used in salt water.
8. Drain and replace gearcase lubricant.
9. Lubricate splines on the drive shaft.
10. Check power trim fluid.
11. Inspect battery.
12. Check control cable adjustments.
13. Inspect timing belt.
14. Remove engine deposits with Power Tune Engine Cleaner.
15. Check tightness of screws, nuts, and other fasteners.
Every 300 Hours of Use or Three Years
1. Replace water pump impeller (more often if overheating occurs or reduced water pressure
is noted).
Every 400 Hours of Use or Four Years
1. Check and adjust valve clearance if necessary.
__________________
Don S.
  #8
Old January 21st, 2008, 07:01 PM
Thank You Don S for your reply ......I'll pass it along.
  #9
Old January 21st, 2008, 10:38 PM
Bigjohn1's Avatar
Bigjohn1 Bigjohn1 is offline
Good advice so far, after the aforementioned checks are done, next on the list should be the throttle position sensor. This is a super reliable engine with very few reported failures. It is essentially a Yamaha F115 powerhead so you can gain additional insight on the Yamaha forum.
  #10
Old January 24th, 2008, 12:42 PM
mwhitten mwhitten is offline
I had a 2005, 115 that did the same thing. It turned out to be the idle adjustment
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1999 Mercury 4 stroke 40hp low power and stalling djbdjb Mercury & Mariner Outboards 7 November 4th, 2009 07:37 AM
4hp 4 stroke yamaha keeps stalling haddles Yamaha & Suzuki Outboards 1 September 21st, 2005 05:18 AM
99 30 hp 4 stroke stalling cistn Mercury & Mariner Outboards 0 June 1st, 2005 08:12 AM
90 hp 4-stroke stalling chappy77 Mercury & Mariner Outboards 2 June 15th, 2004 09:22 AM
2000 40hp 4 stroke Mercury stalling/surging problems entropy Mercury & Mariner Outboards 0 July 19th, 2003 02:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
