krisnowicki
- Jul 11, 2007
- 1,172
I got my boat up an running after a repower today. It ran awesome... it does not shift so well.... I have a two cable harness attached to the left riser. Which cable do I adjust and how do i do it. It shifts into forward no problem but neutrul is not to be found and when I pull it bck for reverse it has to go way back to shift in to reverse? Any advise would be help ful..... ALSO there is a white wire attached to the harness with the two cables where does this plug in to ? It is the only one i did not label thank you
