I'm rebuilding the carbs on my motor and noticing a few things after reading alot on here about it.
The carbs look clean, no gumming/oils, the metal is almost shiny, can they be dirty even when they look clean?
Also I got the kits and noticed on ishop's diagram that it shows two different orfices for the upper and lower carbs, but the kits just have one orfice only. Do I need to order the other one or should they be the same? I will take them apart and see if there is any difference between the two but wondered if I should get one ordered.
that is not an orifice, it is the float needle seat. item 27 in diagram # 35 is the high speed orifice, # 30 is low speed orifice. you need a special screwdriver to remove them.
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
It would be no. 38 on that diagram and Ishop lists two numbers for it. Listed as orifice, idle used on upper carb #0318823 or orifice, idle used on upper carb #0317473. That's my question is there a difference between these two?
I've made the screw driver for removing them and the high speed looks good and clean.
yes there is a difference, but i have never seen a kit come with the the jets. only the needle valve seat and needle. the jets would have to be ordered separately.
