  #1
Old January 14th, 2008, 03:36 PM
Benny1963's Avatar
Benny1963 Benny1963 is offline
Smile evinrude 150 power head removal
pulled power head today because of clicking noise
have checked everything on list stator good upper bearing good
have power head on bench came off onlt took 1hr to remove components
and pull took lots of pic and tagged all wires
got factory manual.im looking for help in what to look for when i split case
and what not to do when i split case any info on tear down and inspection will
help i guess i will be looking at bearings first as i tear down and then take to machine shop block and pistons to have miked.motor has excellent bores
but had run hot once any help on what to look for would be great
thanks everyone bennyb
__________________
Benny B
  #2
Old January 14th, 2008, 07:02 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: evinrude 150 power head removal
If you have not checked for piston play, I suggest that you do so before splitting the crankcase. It might save a tremendous amount of time in locating the area of that "ticking".
(Piston Play Check)
(J. Reeves)
This procedure will tell you if there is any wear or play in the Wrist Pin, Wrist Pin Bearing, or Connecting Rod to Crankshaft area.
Remove the spark plugs. Insert a screwdriver, dowel, punch, or some object of your choice through the s/plug hole and into the cylinder/piston area. Hold the tool lightly against the top of the piston. Turn the flywheel by hand, bringing the piston up to top dead center, then continue turning the flywheel to pull the piston down about a inch..... all the while holding the tool lightly against the piston top.
Now, at the point whereas the piston has been dropped down about a inch, grab the flywheel and hold it firmly. Now, push that tool solidly and firmly against the piston top.
If the piston moves without moving the flywheel, there is a problem (wear, play, clearance, etc) somewhere with the items mention in the first sentence. Be sure to check all of the pistons/cylinders.
When time permits, visit my store (copy/paste) at: stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
25elr72 power head removal marcysibyll Johnson & Evinrude Outboards 4 June 22nd, 2006 07:10 AM
power head removal 50 hp force msman Force & Chrysler Outboards 11 March 16th, 2005 10:11 PM
Power head removal! Melvin Hatcher Johnson & Evinrude Outboards 17 March 6th, 2005 04:38 PM
150 POWER HEAD REMOVAL FOR RODBOLT Reel Precision Yamaha & Suzuki Outboards 5 September 8th, 2004 08:46 AM
30 Horse power head removal Harker Johnson & Evinrude Outboards 4 October 10th, 2003 08:14 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
