Re: 1976 Mercury 115 inline 6 timing
Position the #1 piston at TDC. (you can use a screwdriver to confirm this...accuracy is not crucial)
Install the outer flywheel on the hub such that the flywheel marking lines up with the pointer at TDC. Be sure to torque those bolts to spec.
__________________
'72 Glastron GT160 c/w '72, '84 and '86 Merc 115hp
'67 Merc 3.9hp , '70 Merc 9.8hp, '61 Merc 50hp ... The Merc Nut
