what would cause a 93 johnson 50 w/vro to start and run for 5 min then die. If I squeeze the primer bulb it will start again and run with a vro oil warning sounding. The hoses look good. I replaced the air and fuel diaphams in the fuel pump. Also replaced the pulse limiter. Are there check valves not included with the kits?
