  #1
Old January 10th, 2008, 07:55 AM
LORINE LORINE is offline
Default Water in gearcase 225 yamaha
Hi I have water contamiating the outboard leg on my 2003 225hp 4 stroke yamaha i am replacing all seals o rings ect , my query can i replace the prop shaft seals without removing the prop shaft housing ,irecon i can screw 2 small self tappers into the old seals and gently leaver them out,allso what do u think ??. also should the seals face outwards or back to back(stoping oil leaking out and water geting in)
Thanks maurie
  #2
Old January 10th, 2008, 08:15 AM
rodbolt rodbolt is offline
Default Re: Water in gearcase 225 yamaha
can it be done?
yes
usually though I see the propshaft seal surface destroyed by scratching it when its attempted.
its just to easy to remove the carrier and then you can also replace the carrier orings.
carefuly measure the seal depths on both the propshaft and driveshaft housings. set the seals do deep or to shallow and they will be chewed up very rapidly.
on the yamaha all springs on the seals face out.
carefully clean all housings of corrosion.
while yamaha doesnt specifically reccomend it I use either OMC adhesive M or 3M weatherstrip adhesive on the seal to housing fit, make sure you get no adhesive on the seal lips.
pack the area between the lips with yamaha marine grease or its equivalent.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Water in gearcase, 1987 - 70 hp Grant Brown Mercury & Mariner Outboards 2 April 28th, 2005 05:14 AM
Yamaha late '80s 25-30 HP gearcase interchange questions reach Yamaha & Suzuki Outboards 3 September 26th, 2004 07:04 PM
Yamaha 250 Gearcase Removal SWS250 Yamaha & Suzuki Outboards 0 June 23rd, 2003 07:30 AM
need gearcase for 1979 yamaha 28 tazzy62 Yamaha & Suzuki Outboards 2 June 13th, 2002 03:26 PM
Need Yamaha 115 gearcase Gar Yamaha & Suzuki Outboards 1 January 12th, 2002 02:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
