  #1
Old January 9th, 2008, 10:47 PM
jasper2447's Avatar
jasper2447 jasper2447 is offline
Default Starter dead on Mariner 25HP
Hi everyone and Happy New Year
The starter on my 2007 Mariner 25 suddenly just stopped working after my last trip out and i cannot seem to be able to find the fault.
Does anyone have any idea about what could cause sudden and total failure of a nearly new starter motor between trips and how i should set about testing the various bits.
i have cleaned the battery terminals etc and re-crimped the cables tight - There is lots of charge in the battery but nothing happens when i turn the key to start
I'm sure it's not the starter motor itself ( I might be wrong, but it seems too new to develop an internal fault) so what do i do now???
Best wishes and tight lines
John
  #2
Old January 9th, 2008, 11:01 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: Starter dead on Mariner 25HP
I can tell you that Mercury/Mariner had a run of defective starters from the factory in 2007. I would have the dealer take a look at it. They should have an updated starter to replace it...
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
Old January 9th, 2008, 11:02 PM
JB's Avatar
JB JB is offline
Go to the Engines FAQs, Jasper.
Do the starter circuit troubleshooting in "Outboard won't start".
Let us know what you find.
__________________
RED SKY at night. . .
JB
  #4
Old January 10th, 2008, 01:31 AM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
do you here a clicking?
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #5
Old January 10th, 2008, 09:47 AM
jebeebe jebeebe is offline
When you hit the starter, you should hear the selenoid click. If not ,the selenoid is probably bad,or it is not getting a 12v shot. If it clicks and nothing happens, it is not sending 12v across the large posts, which could be a bad or coroded selenoid. Check the voltage in when you hit the starter. If it is there..........the selenoid should click.
  #6
Old January 11th, 2008, 07:44 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
also have the battery load tested at the auto parts store, free, i've had new batteries go bad
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #7
Old December 13th, 2008, 03:22 AM
pete007 pete007 is offline
Yall keep this one handy YAHEAR!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Flooded 25hp mec now dead in water huffduf41 Mercury & Mariner Outboards 4 July 16th, 2007 12:47 PM
80s mariner 25hp - to remove carrier bearing? swap mariner -> mercury casing casi77 Mercury & Mariner Outboards 3 November 17th, 2006 09:28 PM
Starter is dead scorpion264 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 August 29th, 2005 06:02 PM
dead cylinder on '77 Johnson 25hp coonass729 Johnson & Evinrude Outboards 3 September 2nd, 2003 11:45 AM
bad starter solenoid = dead battery ????? Rollie Force & Chrysler Outboards 3 August 2nd, 2002 07:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
