Our 96 Force just came back from the dealer and they could not find the problem. They ran the diagnostics and everything came back normal. This is the issue. After the boat runs for 30 to as long as 90 minutes the engine acts as though it is starving for gas or choking out. It begins to lose power and you have to back off to idle. It runs fine at idle and accelerating in neutral. If you let the boat sit for a little while, it will run fine again for 30 minutes or so and it will start all over again. This has been going on most of the summer. Some items that have been recently replaced, not necessarily as a result of this problem are, the bendix, spark plugs, battery and fuel filter. Any suggestions would be great.
