beerrun
- Apr 1, 2007
- 134
My project boat did not come with any stringers but i would like to add 2. One to the left of the keel and 1 to the right. Where the keel is there was what looked like a stringer but it did not go up high enough for the deck to rest on it at all.So what was it there for? I have been reading and reading and I am confused about hard spots.What i have read says that you should set the stringer into a bed of thickened resin, but wont that dry as hard if not harder than the wood?
Also, the boat had no bilge. the entire hull under the deck was foamed. If I add a bilge, how would I go about doing it? would I leave the space between the two stringers void of any foam and just foam the sides?I guess I am kinda asking how a bilge works I would also like to have something sturdier than just the deck to attach seating to so I was thinking some frames would be good. Here is a very crude drawing of what I was thinking.
red=stringers
blue=frames
yellow=foam
OR- should I scrap the whole idea and just put ot back how Chrysler had it?
red=stringers
blue=frames
yellow=foam
