  #1
Old January 7th, 2008, 03:28 PM
hokiepoq hokiepoq is offline
Default 1986 1987 or 1988 115hp Mercury carburators - rebuild myself?
I have a 115hp Mercury outboard, an in-line 6, on my boat that I just rebuilt the transom. It sat for a long while before I rebuilt the transom. I took it out this summer to run it and it worked well except it wasn't at full power the whole time. Seems like it was at 2/3 power while I had the throttle all the way down; then moments later it was jump up to full power (from what I could tell) and run a while. It ran smooth while it was running, just not at full power the whole time. I figure the carburators probably need to be rebuilt. Is this a do-it-yourself job? I change the water pump impeller last year myself so I can do somethings, but timing and aligning things up just right scares me. Any advice?
Thanks!
  #2
Old January 7th, 2008, 04:16 PM
rndn rndn is offline
Default Re: 1986 1987 or 1988 115hp Mercury carburators - rebuild myself?
It's a do it yourself job as long as you have a manual. Buy one at "http://www.outboardbooks.com/".
__________________
1996 Crestliner 2160 Phantom, 1996 Evinrude 130 HP
  #3
Old January 7th, 2008, 04:46 PM
achris's Avatar
achris achris is offline
Send a message via Skype™ to achris
That's not a difficult job... The devil is in the detail. Pay particular attention when you put them back on to the linkages between the carbs. Make absolutely sure that all 3 start to open at exactly the same time. Other than that, just work clean and replace the manifold gaskets.
BTW, these are my favourite engines, I love them. Treat her nice.
Chris.........
__________________
The world takes on a whole new perspective when viewed from 100' below...
1972 Bertram 'Bahia Mar' 20
2006 Mercruiser 4.3MPI (OW617679) w/Alpha 1 Gen II (OW829301)
  #4
Old January 8th, 2008, 11:03 AM
Chris1956 Chris1956 is offline
Wink Re: 1986 1987 or 1988 115hp Mercury carburators - rebuild myself?
Hokie, You may have a fuel pump issue instead of, or along with your dirty carbs. To determine this, have someone pump the primer bulb while running at high speed. If the manual pumping of the fuel keeps the motor running at full speed, rebuild the fuel pump.
  #5
Old January 8th, 2008, 01:26 PM
Thanks for the advice guys. Sounds like a good winter project. I found that taking lots of pictures helps me get things together back right.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Hard Starting 1988 115hp Mercury Inline 6 mmccurry Mercury & Mariner Outboards 12 October 31st, 2007 08:05 PM
Hard time finding the right part... 1987 115hp Mercury hokiepoq Mercury & Mariner Outboards 2 July 30th, 2007 08:44 PM
1987 Mercury 70HP lower unit rebuild bigfoot model deasola Mercury & Mariner Outboards 2 August 12th, 2004 07:30 PM
Is it worth it? 1988 115hp mercury bolted4 Non-Repair Outboard Discussions 4 September 10th, 2003 06:58 PM
mercury xr4 150 carburators cleaned texasfish Mercury & Mariner Outboards 5 October 8th, 2001 08:18 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
