this is driving me nuts - new plugs, carb cleaned (24 hrs in carb cleaner) but it continues to run rich in the tank. 1/2 hr. of fast idle run time and I've got a black ring on the lower end ( not oil as it is powder after letting it dry).plugs are sooty. the manual I have says to set float height @ 10mm with carb upright measuring between body and top of float??? I ignored that and held it upside down, measuring to the bottom of float. changing pilot jet setting has very little effect on idle speed or quality. new thermostat, timing checked, coil o-kay,starts fine(2-3 pulls cold). Any ideas? thanks
