Envirude Fisherman 6HP
JESUS8916
I recently got a envirude fisherman 6hp with the serial number being
6502M - E09985 can anybody tell me what year this motor is?
Part 2: I was working on the motor and broke part. The part has 2 funsctions.
When you turn the tiller arm this part which is mounted to the motor body turns and moves a shaft through the outside of the powerhead which contols the throttle. I broke the part where that shafts sits on. This is the best I can describe it.
Pleas help me locate this part and identify the year of motor.
Vic.S
Re: Envirude Fisherman 6HP
I make that a 1965 model.
The parts diagrams on the brp website at "http://epc.brp.com/default.aspx?brands=ej&lang=e" only go back to 1968 and even that does not seem to show the part you describe
ezeke
If you can identify the part by the diagram number, I will try to get the part number for you:
JESUS8916
Thank you for that quick response.
The part in the diagram is 72 and 73.
Let me know where I can find these parts.
ezeke
Part # 72 is OEM # 303140 and is called "Bushing, Throttle Control".
Part # 73 is OEM # 308187, superseded by # 324512 and is called "Gear, Throttle Control".
Both parts are available through a local J/E BRP parts department, though the prices may surprise you. Some of the salvage yards may also have used parts at a good discount.
The parts were in use in models as late as 1979, so the ones shown on the diagram are probably the same as you would find on the 1968 model at the BRP parts catalog site:
