Started runing into a problem with my engine where it would idle perfectly then i could put it in gear and move at a trolling speed but when i would put the throttle down it would bog out and stall. I did some trouble shooting and cleanned the fuel filter and changed the spark plugs same thing still happening. Then while it was running i disconnected the spark plug wires one by one and found that the #2 clinder was not firing. what could be causing this to not fire?
Just found this forum and have got lots of info from it so far.
first post.
Thanks for any help.
Ryan
first post.
Ryan
