93 225 yamaha 2 stroke ,coughing
i was having a problem when sihfting from nuetral to forward the engine would die , i could pull the trottle to the side for high idle and rev it up ,then before it when back to idle speed shove it in gear ,[ had to do it to get back to the dock] i checked the thermosensor , knock sensor , cam pos sensor ,all good but the ,throttle pos sensor i cant get a propper reading ,maybe because i am not using a yamahe dig .meter ? on standerd dig meter on 20k setting i get 5.ohms . but when i adjust the sensor the engine will rev up or down . also i changed the filter was dirty added water remover ,octane booster ,seems to be running better [in a test can prop removed ], but will cough at high dle around 10-1300 rpm like it loses spark all at once then recovers , any ideas what i should check ?
