12ft sears gamefisher jon boat
Status
Not open for further replies.
gins331
Can anybody tell me how big an outboard I can run on this boat? and be safe its pretty small, the only info tag I found said two person or 300 lbs thanks
guy74
Re: 12ft sears gamefisher jon boat
I'm not familier with that brand, but I have two 12' flatbottom jon boats. The Lowe is rated for 3hp the Landua is rated for 5hp, and both are rate 2 persons or 350 lbs. I would think that would be in the ballpark.
gins331
Thanks have 6hp evinrude might use but gonna look for 3-5hp with gas tank on top cut down on tank on floor not much room in it
erie_guy
Gins31,
I have a 12' sears, but with a V-hull. It is rated (nameplate) to have up to a 10 hp engine and 300# passanger load. I would guess yours would be ok with similiar hp engine. I personally have a Nissan 8hp on mine and it can plane easily with a full passenger load (usually 2 adults, 2 kids, and fishing gear) It also moves easily with a bow mounted minitonka electric w/35 # thrust.
Enjoy this fine fishing weather while we can !!
erie_guy
Port Clinton, OH
Campylobacter
Ginns-
Fiberglass or aluminum? My father has a 12' fiberglass gamefisher and its rated to 10 HP. He runs the 10 no problem. I would not describe his as a John boat however, more of a semi-vee (perhaps like erie_guy's). If it is a flat bottom you won't want to go that high.
Bob_VT
you can run up to 5.hp motor
Thank you for your reply...... that post is two years old!! I can image the original poster got his answer....
Welcome to iboats!
Feel free to look around and become a contributer to current topics or start your own ;)
This one is going to get "locked" by me so it can slowly settle into the archives ;)
Status
