We have a 2007 maxum 19 ft. with a V6. How do you reach the drain plugs ???
A abebka Recruit Joined Sep 27, 2007 Messages 1 Oct 21, 2007 #1 We have a 2007 maxum 19 ft. with a V6. How do you reach the drain plugs ???
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,480 Oct 21, 2007 #2 Re: drain plugs On most new boats,....... Long Arms,...... Skinny Fingers,..... And,..... Being Double Jointed seems to Help....................
R rndn Commander Joined May 20, 2007 Messages 2,323 Oct 21, 2007 #3 Re: drain plugs Should be from the outside in.
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Oct 21, 2007 #4 Re: drain plugs outside, in, as stated, and you run a bilge pump.
jspringator Chief Petty Officer Joined May 27, 2006 Messages 415 Oct 22, 2007 #5 Re: drain plugs Do you mean manifold and block drain plugs? Look at your owner's manual. You may have to move some stuff around to get to them.
