Lunderful Life
- Oct 20, 2007
- 2
I am trying to diagnose my problem. The tilt and trim has been sporatic for a while: I would have to press the button multiple times before it would engage, then it would work fine for the day. Most recently though, it has stopped working altogether.
Using the manual, all the voltages and tests check out. I am wondering if the electric motor itself could have a flat spot in the armiture? Shouldn't the motor run if I apply 12V directly to the leads? (Because it does not.)
Is applying power directly to the leads of the motor the way to see if it runs or not?
Thanks,
Steve
Thanks,
Steve
