  #1
Old December 30th, 2007, 05:06 PM
patman1776 patman1776 is offline
Default New Bayliner Bowrider 185 questions
Greetings!!!
Just bought my first boat (2008 Bayliner Bowrider 185 Fish and Ski) at Cabela's up here in Hartford, Ct. I stayed with the stock Mercruiser 135 hp engine, but have a few questions regarding this choice: Will it be sufficient to pull tubes, skiers, and wakeboards??.......As I didn't want to spend the additional 3k+ for the 4.3L Alpha, I stayed with the stock powerplant hoping it might have enough power.
  #2
Old December 31st, 2007, 01:20 AM
RGrew176 RGrew176 is offline
Default Re: New Bayliner Bowrider 185 questions
You should be OK. I had a 16' Rinker with pretty much the same engine. It was a 4 cylinder rated at 120 HP and I had no problem pulling a skier or people on a tube. Did not try to pull a wakeboard though but I would think it would not be a problem. BTW one of the skiers I pulled weighed 270 lbs and I got him up and out of the water with no problems.
__________________
Rick Grew
1999 Bayliner 3055 Ciera SE, Happy Together III
Out of Bolles Harbor, Michigan
2004 Past Commodore
West River Yacht & Cruising Club
  #3
Old December 31st, 2007, 01:22 AM
As a new Bayliner you might want to check out and join the Bayliner Owners Club.
Check them out at: www.baylinerownersclub.org
__________________
Rick Grew
2004 Past Commodore
  #4
Old January 2nd, 2008, 09:43 PM
Wotam Wotam is offline
"Will it be sufficient to pull tubes, skiers, and wakeboards??."
Sure.. try your stock prop first, but you may want to get a 19" pitch prop for watersports. More pulling power out of the hole at the expense of some top-end speed.
Keeping experienced tubers 'entertained' is hard work on the boat (slinging them out of a 'hole' in the water).
Pulling up wakeboarders is easier than skiers... count 1-2-3 as you roll the throttle on. A smooth application of power is the key. You don't want a slammin' holeshot or you'll pull the line right out of thier hands.
Hardest thing will be pulling up an adult single skier with 4 or 5 passengers in the boat.
Whatever prop you get, invest in a good quality one... do some research.
  #5
Old January 4th, 2008, 08:10 PM
billbayliner billbayliner is offline
The 3.0 will be no problem at all. If I were to buy another capri I would get the 3.0 again as it is a work horse and absolutely cannot beat the gas mileage at cruise. I cruise it at 3500 RPM.
I run a 14.25 x 21 prop on my 1950 Capri as this is what gets me my proper RPM at WOT (Wide Open Throttle). Be sure to check yours on the boat as it is very important). Prop Not a problem when pulling the young kids on the tube but it is a little over proped when my daughter takes all her adult friend on the boat.
As Wotam states you will have to fool around with props to get the best set up. Fortunately the props for the Alpha drives can be had for under $100. Got the Michigan wheel prop mentioned above from boatfix for $72 a couple years ago.
Bill
  #6
Old January 5th, 2008, 01:02 PM
BAYLINER185's Avatar
BAYLINER185 BAYLINER185 is offline
Send a message via Yahoo to BAYLINER185
I have the 07 185 basicly the same boat except mine has the 4.3
I hat the 3.0 in my old webbcraft ( wellcraft clone ). It was a bigger heavier boat and the 3.0 did fine back then rated at 120 Hp.
It was a great little motor and I could tell that it woul have pulled skiers tubes and what not just fine. I did start getting the cravign for more go power after about a year with the boat but it did do 40~45 MPH.
My 185 does 55 MPH with a 23" pitch SS prop. I think youll be fine with the 21
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Replace 2 piece cover on 86 Bayliner Bowrider slayt Boat Topics and Questions (not engine topics) 0 August 6th, 2007 02:25 PM
89' 125 Force on 89' Bayliner Capri Bowrider Prop? Reel-Fun Prop Questions and Topics 8 August 6th, 2006 09:26 AM
1989 Bayliner Capri Bowrider w/ 125 Force Reel-Fun Force & Chrysler Outboards 7 July 28th, 2006 09:07 AM
1989 Bayliner Bowrider Capri Open Bow Replace Interior Question retrojeep Bayliner Boats 4 July 9th, 2006 09:56 PM
1989 Bayliner Capri Bowrider w/ Force 50hp o/b Rodb Force & Chrysler Outboards 6 June 7th, 2006 02:48 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
