Quote:
Originally Posted by Yostie
Sincere Thanks J Martin That's the information I was hoping to get from my first post.. Had already done the obvious, and had a manual on the way.. Was unaware that the adjustments were so extremely sensitive.. I am somewhat impatient but not ignorant.. engine is probably toast now anyway, guess I'll find out when manual arrives
When you get the book and learn how all that junk on the port side of the engine relates, you can maybe just back off what you did and go from there in troubleshooting mode.
Odds are, judging from what you said in the original post, it's a problem with the hotfoot or the cable to it. I noticed Gander Mountain carries one model of the Hotfoot, and a replacement return spring for it. (in stock)
Idle speed is mostly controlled by timing. The idle stop screw should hit the stop every time. If it doesn't it's a cable or control problem. The next thing in the sequence is the cam picking up the throttle linkage. Both idle timing and throttle pickup timing vary from model to model. That's where the book comes in.
If everything is timed right, and your compression is good, odds are you broke a bleed line or have something loose in the front end that's letting in air. It'll toast the motor in short order if that's the problem and it's not fixed.
(edit) Just came to mind, if you have an idle stabilizer module on it, and it shorts out bias to ground, idle will speed up, and so will max timing. (destruction in short order)
These engines aren't very complicated, but they normally run on the hairy edge of self destruction, so small things can turn into big problems pretty quickly.
hope it helps
John
