Motor Fire
1983 80 HP Merc
Out on the water, I ran a 6 gal tank dry, then hooked up a fresh tank. Primed the bulb, apparently one or both carbs were flooding from floats/seats not sitting properly after running them dry. Motor would not start. Apparently loaded up motor with fuel. Motor backfired and caught on fire. Pulled front cover and band off motor and extinguished fire quickly, got home ! to see no major damage, melted wires, etc. Pulled carbs, ( they were rebuilt this season and floats are at the proper height adjustment that factory manual says to set them.) and re-set floats/seats. Motor fired right up.
I have read threads here about carb/float flooding issues but haven't read one about any problems with floats/seats not sitting properly after running carbs dry. In fact, there is ongoing debate here about running carbs dry in order to avoid leaking carbs when tilting up motors for trailering, and to avoid carbs gumming up during the off season.
My question: is it simply time for new floats? They are original, although they don't seem to be saturated. Do you think the new plastic floats would fix my problem. Has anyone here experienced this problem?
Thanks in advance and would love to hear about anyone else's experiences with this carb issue.
1983 80 HP Merc
