sehoner
- Jun 7, 2007
- 18
so i took my 73 85hp rude to the shop. it wont stay running under load or idle. i thought carbs right? tried to flush with seafoam and the motor ran for a second and died, then wouldn't start again. the mechanic said the power pack had been replaced and a bunch of other things were "newer". he said he would run it today and that it probably wouldn't need a carb rebuild since the electric choke was gummed up that may be the problem.
he called today and said that he tried to run the motor and it had no spark with the plugs in , but it did have a spark with the plugs out. apparently when they upgraded the power pack they didn't install a "timing sensor" to match the new vinyl coated pack since the old one was in an aluminum case it wasn't set right. he said he sees it a lot on older motors. he also said he wants to check a electric choke switch or something that is on top of the cylinders under the flywheel as it may not be functioning and cause the choke to stick open.
i really don't know much about boats so maybe you guys could let me know if this sounds legit.
thanks, Rich.
thanks, Rich.
