Re: black, oily spark plugs
bookryan, your driving style and application has a lot to do with it. Do you putter along most of the time, or WOT? Do you run for extended peroids or do you shut down and start up often? I spend most of my time on plane between 60-100% throttle, and I only start-up/shut-down 4-5 times in a whole day. I also run a decent grade of 2 stroke (not full synthetic though), with TCW3 rating. I know from the couple of 2 stroke motor cycles that I've owned that the really cheap 2 stroke oils leave more deposists than the better brands/ratings.
But since you can just wipe them off, and you have no performance, rough running, stumbling complaints, you're fine.
