  #1
Old December 24th, 2007, 12:41 PM
cgustafson cgustafson is offline
Default Evinrude 6hp intermitent power and what yr?
I have a 6hp evinrude that has intermitent power I have to engage the choke in and out in order to keep it moving. Any ideas? My serial # is 6002B-E02259 can someone tell me what year it is. Thanks for yoyr time ans Happy Holidays.
Carl
  #2
Old December 24th, 2007, 01:02 PM
wildmaninal's Avatar
wildmaninal wildmaninal is offline
Default Re: Evinrude 6hp intermitent power and what yr?
It is a 1970 model from what I observed.
Have you done a compression check? Is it hard to start?
Welcome to Iboats and happy holidays to you and yours.
  #3
Old December 24th, 2007, 01:13 PM
flabum flabum is offline
Fuel starvation. Sounds alot like the carb is gummed up or has trash in it. Either that or a bad fuel pump, leaky fuel hose or vent on tank is closed or clogged. My first bet would be the carb.
  #4
Old December 24th, 2007, 01:19 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
totally agree.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old December 24th, 2007, 01:43 PM
Wow thanks guys for the quick replys
It starts on the second pull always. I have not performed a compression check.
I inspected the fuel tank looks like the vent is free. I will have to look further into the other issues. I need to get a manual on it before I start taking it apart.
Happy Holidays All!!!
  #6
Old December 24th, 2007, 01:57 PM
ondarvr ondarvr is offline
Some of the 6hp motors in that time period use a cork type gasket, or ring near the main jet in the carb. This gasket will break down and fall apart, these small chunks can get stuck in the jet and will cause problems just like you mentioned.
  #7
Old December 24th, 2007, 01:58 PM
Quote:
That is a great idea, highly recommended by all these guys here. Also here is a website to find your part number for that motor.
"http://epc.brp.com/login.aspx?ReturnUrl=%2fdefault.aspx%3fbrands%3dej %26lang%3de&brands=ej&lang=e"
Just copy the link and paste it to your address bar on your browser.
  #8
Old December 24th, 2007, 02:06 PM
jay_merrill's Avatar
jay_merrill jay_merrill is offline
I think everyone has pretty much hit the nail on the head, as "they" say. Sounds like junk in the carb.
If the motor has been sitting around for a bit, rebuilding the carb, fuel pump and water pump is a good idea. The carb and the water pump are easy to do but I have to admit that I am lazy about the fuel pump and usually just buy a new one. They really aren't all that complicated but are sort of a pain to put back together.
You have a great little motor which will run "forever" if serviced occassionally.
  #9
Old December 24th, 2007, 08:29 PM
gvegas88 gvegas88 is offline
I have a Johnson 1970 6hp seahorse that truely runs better than I could hope for. It has been taken great care of and has fresh carb, water pump, sparks, cleaned cylinders and new head gasket. I use it alot and especially hunting this time of year, I will admit it takes a beating some places from stumps and a crazy captain. I have long term plans for it, so what "service" should I annually do to ensure that it will last?
Thanks, Tyler
  #10
Old December 24th, 2007, 10:24 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Tyler Im not sure where you are from, but if the motor gets stored during the winter months, ensure it is properly winterized. Keep an eye on the lower unit oil, and change it out at least every fall, along with new gaskets on the drain and vent screw. The carb should be rebuilt every 2 or 3 years, although with the newer fuel, that could soon become every year. Running seafoam mixed with your fuel helps alot. The impeller is a critical part of the cooling system and should be changed out about every 3 years.
__________________
Chris
  #11
Old December 26th, 2007, 12:16 PM
superflydudebike superflydudebike is offline
I have a 1972 6 HP Rude and it is a gem.
  #12
Old December 26th, 2007, 12:52 PM
DJ DJ is offline
The parts are available, right here on iboats. Below is a C & P from the iboats parts finder.
6 hp 1954-1979 18-7043 9-37106
If you have a cork float, replace that too. They are known to sink.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Power Trim Switch Intermitent Problem Ratzax Mercury & Mariner Outboards 5 May 28th, 2007 01:09 PM
intermitent power loss scottrece Mercury & Mariner Outboards 4 May 6th, 2006 08:05 PM
Intermitent power trim 88 force 125 baylner formerterp Force & Chrysler Outboards 3 July 2nd, 2004 06:50 AM
1992 140 Johnson intermitent power loss 11WFLA Johnson & Evinrude Outboards 3 October 21st, 2003 05:24 PM
Intermitent lose of power.. Hollis Non-Repair Outboard Discussions 3 July 1st, 2001 01:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
