  #1
Old December 23rd, 2007, 06:50 PM
SuB8HaVeN SuB8HaVeN is offline
Send a message via AIM to SuB8HaVeN
Default 1989 Yamaha 40hp 2 stroke 3 cyl CDI issues...
Hey guys, I bought a boat a while back with a 1989 Yamaha 40hp 2 stroke, 3 cylinder that I've been raking my brains over trying to get it running right. Initially it had sat up for a couple years, so I went through the carburetors with a new rebuild kit (about 4 times now), replaced the fuel filters and cleared out the lines, pulled and capped the oil injection system (I'm running premix now), changed the plugs, and pulled the powerhead and replaced the lower crack seals and the gasket between the powerhead and middle shaft.
It will basically run like a charm for the first 15-20 seconds when you first crank it, but right after 15-20 seconds, it will begin to spit and sputter and die out. I bumped up the timing enough so that it will run like this, but you can tell it's only on 2 cylinders of the 3. I have narrowed the problem down to the bottom cylinder because you can pull that plug while it's running and it makes no difference to its tone. When you pull the middle or top plug, the motor will die. The bottom plug also looks a little cleaner to where it doesn't seem to be burning right. You can see the bottom cylinder is getting spark, so it shouldn't be the coil. I pulled the CDI Mitsubishi timing box module thing and went through the wires to make sure all the connections were good and it all checked out.
I ran it on the water a week ago, and it did the same thing. When you first crank it, it will run like a dream until about 15 or 20 seconds and it will start to die out (it starts running on 2 cyl). I also noticed that if you do a hole shot and floor it, it will kick up and throw you out of your seat (definitely on all 3 cylinders), but after about 3 seconds it will die back down. It seems that at certain points or situations it sends correct spark to the bottom cylinder, but other times it doesn't to where the bottom cylinder isn't firing right or making power. When you open up wide open, it will go but it spits and sputters and doesn't move very quickly, so it definitely is running on the top 2 cylinders only.
I just wanted to check with you guys and get your opinion. My last resort is to replace the CDI unit since I figure it isn't sending correct spark to the bottom cylinder, therefore causing all the problems I mention. It doesn't seem to have any damage or corrosion or anything (the entire motor actually looks like new under the cover). So, should I spend $400 on that darned CDI box, or is there anything else I can try? Also, does anyone know of a cheaper solution; can I send the CDI box to some place for repair at a lower cost? Thanks in advance!
Edit: I forgot to mention, but the compression in all 3 cylinders is spot on and I did a leak down test and it is almost literally perfect. It doesn't seem to knock or make noises, so it shouldn't be anything internal.
  #2
Old December 24th, 2007, 10:00 AM
Ray Neudecker Ray Neudecker is offline
Default Re: 1989 Yamaha 40hp 2 stroke 3 cyl CDI issues...
Intremitent CDI failure for the 3 cylinders is not uncommon. The last time I talked to Rapair or I think they are now CDI electronics, they were making a replacement for it.
I think I may have a used one which was working fine when the motor croaked from lack of water pressure.
E mail me at neudecray@hotmail.com and I will look and see.
  #3
Old December 24th, 2007, 11:30 AM
Thanks for the info, I sent you an e-mail.
  #4
Old December 25th, 2007, 02:23 AM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
start testing the components
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #5
Old December 25th, 2007, 07:01 PM
ianyoung77 ianyoung77 is offline
The 15-20 seconds thing is normal. Initially the CDI seems to advance and then die back to idle. The CDI's job is just to send a spark so if you think it is not sending one to the 3rd cylinder you can attach a timing light and see if it stops sending. Certainly you need all three cylinders to throw you out of your seat but dying after 3 seconds could suggest a fuel issue.
  #6
Old December 26th, 2007, 12:39 PM
SiLiconD17 SiLiconD17 is offline
Well, I ended up ordering a new CDI so we will see what happens. Is there anything else worth replacing at the same time? I was going to order the coils but I think they were about $60 a pop, so I passed on that offer. I'll let you guys know what happens after I get the new CDI in.
  #7
Old December 28th, 2007, 10:52 PM
rodbolt rodbolt is offline
your most likly going to have a spare CDI box.
a better way to test it would simply check the primary coil voltage at all 3 coils to see if one is missing an input.
next best would simply be to index the flywheel for cylinders 2 and 3 and simply run a timing light and insure the correct plug was firing.
some of the 3 cylinders ran a box with a TPS inside that was driven from a rod on the throttle linkage.
other old ones had 3 pulser coils and CDI failures were rare.
in 12 years or so of playing with yamaha I may have seen 2 bad coils, and maybe 5 bad CDI/ECU failures.
its just rare.
thats why proper testing is so mandatory
  #8
Old December 28th, 2007, 11:00 PM
Hercules0630 Hercules0630 is offline
Default Johnson 75 problems
First the engine was stuck in reverse. Then I got the tilt and trim to pick the engine up to see WTF was going on. Tilt and trim stuck up all the way. Filled up the oil reservoir on it. Think the rings are going bad in it.
It's still stuck in reverse. Took control panel off and cleaned up the junk in there. Lever works somewhat better, but still something is wrong. Still stuck.
Any help appreciated.
Just got this boat last month....
  #9
Old December 29th, 2007, 10:41 PM
Unfortunately, he does have the model with the tps built into the CDI box. The most likely to fail and the hardest to trouble shoot when they are intermittent.
  #10
Old January 8th, 2008, 12:54 PM
yep, thats why the test wheel,flywheel indexing and a CD77 are so important.
I have also found if the pointer on the CDI goes past the mark it will create isues.
but the nedle will deflect rapidly at coil misfire on a CD77 that a digital meter may or may not see. the timing lamp with the flywheel indexed will show if a cylinder disapears or fires at an incorrect time.
but the test wheel is about mandatory.
  #11
Old January 8th, 2008, 01:14 PM
grid grid is offline
I didn't see anything about shooting a little fuel into #3 carb to see if it picks up RPM again. Quick & easy test to discern if it's carb or electrical. I'd also reattach the O/I lines, or remove the entire system-drive gear and all, and install a cover plate. When that drive gear runs too long without lube it'll lock up and destroy most of the bottom of the crank. You may also want to make sure you installed the bottom crank seal in the proper direction, as you could be blowing fuel out there instead of drawing it through to the combustion chamber. As far as stuck in reverse, disconnect the control cable from the shift at the engine and see if you can then select gears manually moving the shifter on the engine. If not, check where the shift rod connects just above the lower unit. Water may have eroded it util it won't swivel the gearcase part of the shift rod. Don't you just love boating?
  #12
Old January 9th, 2008, 09:56 PM
curcioa curcioa is offline
Unhappy HELP Re: 1989 Yamaha 40hp 2 stroke 3 cyl CDI issues...H E L P
Getting Desparate
SuB8HaVeN maybe you can help as it seems you are little further down the road than I am. I need help identifying the part numbers I need.
I made the mistake of buying a:
Late 80's Yamaha 40 hp Enduro
It fell in the river and the CDI appears shot, maybe coil as well.
The part number on the Mitsubishi CDI reads (in 3 lines):
66T-00
F8T18471
7Z01
of course no one in the US can cross-reference it.
Any potential info you can share regarding model numbers, serial numbers, codes, or part numbers would be greatly appreciated.
What is the part number on you CDI?
Unfortunately, the plate is gone so I do not have the exact model number or serial number. I dont even know the exact year.
Here is some of the "possible" info for it
Late 80s early 90
Possible model number: 6J4 1984- 40JM
The 6J4 was made 1984 onward
Code 6J4
Model 40JM
A sample late 80s Enduro Serial number:is: 6J4-S-010565
Addition model numbers are:
267080, 267081, 267082, 267200, 267201, 267211
  #13
Old January 13th, 2008, 06:28 PM
hellopeople20999 hellopeople20999 is offline
does anyone no were i can get a cheap crankshaft for a early 1990's 40hp yamaha 3cyl..thank you
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 40hp 1989 not idling... timing? SiLiconD17 Yamaha & Suzuki Outboards 11 October 6th, 2007 09:30 PM
1990 Yamaha 40hp carb issues... SiLiconD17 Yamaha & Suzuki Outboards 3 September 8th, 2007 08:41 PM
Yamaha 4hp 4 stroke idling issues haddles Yamaha & Suzuki Outboards 0 September 3rd, 2007 06:04 AM
Yamaha 40HP 2 stroke to 50 HP? Graham Anderson Yamaha & Suzuki Outboards 2 July 6th, 2007 01:24 AM
1989 Yamaha 40hp - used motor, low compression zio228 Yamaha & Suzuki Outboards 0 May 16th, 2007 04:21 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
